Friends, I bought the Bluetti EB150. I’m new to the solar world and I’d like to ask a question!
The specifications for the EB150 say that it supports panels of up to 500W, 16 to 60V (voc), 10A Max. So my question is, can I use panels with a current above 10A, since I find more powerful panels with a current of 11 to 13 A? If I use a panel with a higher current, will there be any problems with the EB150?
I want to connect 2 240W panels in series. Below are the complete specifications for the panels. I would really appreciate it if anyone could answer my question, since I don’t want to damage the device.
Nominal Power (P.max): 240W;•
Open Circuit Voltage (VOC): 24.5V•
Voltage at Nominal Power (Vmp): 20.6V;
Current at Rated Power (Imp): 11.65A;•
Open Circuit Current (isc): 12.50;•
Module efficiency (%): 19.72%;
Normal Cell Operating Temperature (NMOT): 45C•
Supported Temperature Range:-40C to +85CMaximum system voltage: 600 VDC.•
Internal Protection Fuse: 20A
