Subject:
Hello everyone,
I recently became the proud owner of a Bluetti EB70 and I plan on using it for my travels in my old van (Citroen Acadiane). My idea is to install a solar panel on the roof of the vehicle to recharge the Bluetti while on the move.
I have a specific rigid solar panel in mind that meets my requirements in terms of length, width, and weight. However, I am unsure if its technical specifications are compatible with the Bluetti EB70. Here are the details of the panel:
Dimensions (L x W x H) 1480 x 670 x 25 mm
Nominal Power Pmpp: 200 W
Type of Solar Cells: Monocrystalline
Nominal Current Impp: 7.35 A
Short-circuit Current Isc: 7.79 A
Nominal Voltage Umpp: 27.22 V
Open Circuit Voltage Uoc: 32.35 V
Number of Cells: 196
Cell Efficiency: 21.4%
Cable Length: 0.5 m
Protection Rating of Junction Box: IP67
Power Tolerance: 0-3%
System Voltage: max. 1000 V
Connections: MC4
Number of Bypass Diodes: 1
Operating Temperature: -40 °C to 85 °C
Can anyone tell me if this panel is a good fit for the Bluetti EB70? Are there any other factors I should consider?
Thanks in advance for any help!
Best regards from Germany, Ziggy
