Hello, I’ve only just bought an AC180 myself so am no expert, however I have a few other panels and power stations. I believe the key statistic for the panel is the Open Circuit Voltage or VOC, this gives the voltage that goes from panel to the battery. If I’m looking at the right panel on Amazon, its VOC is 35.12v, well within the AC180’s 60v maximum, so you should be good to go (I’m getting a 435w panel next week so am in a very similar position). I know there can be spikes in the voltage depending on weather, temperature and so on, but you/we should be comfortably within the AC180’s limits.
