Solar charging unstable charger 2
Why are I getting weak and unstable solar charging through my charger 2?
I am pairing the charger 2 with the Elite 200v2 but cannot get a stable solar input through the charger 2. I have bypassed the charger2 to confirm the solar panel and wiring is ok and it gave me good strong stable charge then wired back through the charger 2 and back to weak unstable charge. I suspect a fault with the charger 2? Charging from the car alternator is excellent just need to rectify the PV solar charge. I have double checked connections are good and as should be in the manual.
Good troubleshooting so far that definitely narrows it down. Since the solar input is stable when you bypass Charger 2, the panels and wiring are likely fine
I have the same problem, did you find a solution?
I also got the same problem. For me it seems that the FW of the Charger 2 is not working very well…
