Solar charging the B230
Is the D050S required to use solar panels with the B230 or can you use a 7909-MC4 connection?
After further research the answer is yes, you need the $199 D050S to solar charge the B230 separately. It can’t be charged directly.
@Alan_Walls
Yes. If you want to charge the battery pack with PV, you need an additional adapter D050S. The exact connection is
solar panel–pv charging cable–D050S–battery pack
