Hi , my EB3A will not charge via solar input , my EB55 does not have a problem ?
Regards Pete
- What is the VOC of the solar panel? Is the connection cable plugged in properly?
- Is the car charging can be used normally?
- If the car charging can be used, that is, there is no problem with the machine. It may be the solar connection cable or the panel problem, please double check.
