For more than a decade, I’ve used solar chargers when camping, hiking, and for emegencies. The largest solar charger I own is 30 watt foldable and it has done quite a good job at re-charging my compact lithium USB-A/USB-C battery packs. As we have gotten older, my wife and I have transitioned into car camping trips for two to three days at a time. We still love to tent, but we also would like to have a couple comforts of home, like a small 12-volt cooler for perishables, etc.
To that end, I’ve been looking at the Bluetti AC50B power station and I am strongly considering it for purchase. After doing some “charging time” calculations, I decided to buy a BigBlue SolarPowa 100 folding solar panel to re-charge the power station. The SP100 has a built-in SAE connector and includes a SAE to DC 5.5x2.5mm cable (which is useless with the AC50B, because it requires an XT60 connector for charging). Everything on the surface looked great until I took a closer look at he specs on the solar panel and power station.
After watching a couple of YouTube videos, I became concerned that my new solar panel’s Voc (open-circuit voltage) may damage the AC50B, because the solar panel’s Voc is 2.2 volts higher than the maximum charging voltage of the power station.
Are my concerns justified? Wouldn’t the AC50B’s internal MPPT Charge Controller protect the unit from damage?
Would a separate in-line MPPT Charge Controller reduce the voltage before the electricity even arrived at the XT60 charging port? I would like to keep the SP100 solar panel and find a good work-around. Is there anything that I haven’t considered. Your help would be greatly appreciated.
