Simple Wh statistics for AC180 or simular
I know that the large models can show more advance statistics but the below could be a nice feature for something like the AC180.
Would be nice with some simple statistics for DC/AC input and output. Just the ability to read simple Wh value for each since last reset date. And then it such be possible to reset these values by setting the last date to current date.
This make is very easy to measure during a period how much Wh was delivered by the unit and if only using solar a great way to see how much I have saved in that period.
@bluettiuser1000
Thanks for the advice.
First, you have to be connected to the internet to upload the data. But there is no way to have data on models that don’t support WiFi.
AC180 factory setting does not support WiFi function.
I’m aware that Bluetooth does not allow for heap of data being transferred.
However since you already show PV, Grid, DC and AC watt live data when using bluetooth perhaps there could be room for showing PV, DC, grid and AC Wh since xx/yy-year date. As I stated, just total sum of Wh for each, like:
Total Watt hours since xx/yy-year (last reset date)
PV input: 2000Wh
Grid input: 900Wh
AC output: 1000Wh
DC output: 500Wh
And then add a reset statistics button that will set xx/yy-year to current date and each sum field is set to 0. This way you only need to transmit 4 data values and reset date timestamp. The data doesn’t even need to be live updated if that is a problem
It is very interesting to be in this forum, with opinions that are very relevant to solving problems and learning more about our equipment. Without a doubt, BLUETTI makes a great effort in this and it is appreciated
In relation to the proposal, what would be the actions to upload the data on the Internet?, it would be interesting to know in case they are needed.
