Serial number for B300S?
I’m wondering where to find an individual serial number for the B300S.
At the side there are two stickers with product (?) numbers only:
P/N: 17.0301.1029-01A1 on the one
and
P/N: 17.0301.1030-01A1 on the other
Identical for all batteries.
Have you tried finding them in the Bluetti app, if you can run that? It looks like the app can’t do that.
There should be a sticker on the bottom of your batteries with a barcode. I always assumed this was the serial number. Here @BLUETTI says battery packs do not have serial numbers.
I just checked. The Bluetti does not show any serial number for the B300 or B300s batteries.
Assumed a battery is faulty: How to make a complaint for this battery
if there is no way to exactly specify it? Then any (other) defect battery,
even an old(er) one without warranty, could be returned for repair/exchange.
@Bluetti shurely has the possibility to check - maybe also by a remote control?
Hi @digait
just wondering, if you connect the B300S to a AC500 right now? In the section of BMS Update, can you see the B300S there? Atleast for my B210 thats running with AC200L, i can find a SN this way.
There is acually no QR Code, because the expansion batterys cant be used stand alone with the bluetti app. They always need a host machine to do firmware updates etc.
Contact Bluetti Support. They can give you a set of instructions to test the B300s battery through the AC500 controller. I had a situation a month after receiving my AC300 and B300 in September 2022 and with those steps I discovered that the AC300 had the battery controller damaged. They sent me a replacement AC300 which has been operational for two years. The B300 battery has not failed.
