Hi folks: I’m completely blind without easy access to sighted assistance. I know on the AC200L there’s a way to disable and reenable bluetooth via the settingsmenu accessed by pressing AC and DC buttons at the same time. Would someone mind telling me: 1. How many times I’d have to press the DC button to get to the bluetooth icon never having accessed the settings menu before on the unit? 2. If I get to the bluetooth icon and press AC and DC at the same time to enable or disable it, then either wait a minute or hold down AC and DC again to exit the menu, if I go back into the settings menu, do I always start from a top position or is te behaviour that I’d end up where I last was?
@Shuteye Welcome to the forum!
- Long press AC+DC, press the left AC key 4 times, press the right DC key 1 time, then long press AC+DC to confirm.
- Turning it on again will restart it from the beginning.
Worked like a charm :) thanks so much for the quick reply! I’m now safe in the knowledge that I can set things up with the app, and then turn off bluetooth to prevent anyone from cntrolling my AC200L without physical access ![]()
Supplement: Make sure the machine is in a screen-on state when performing these operations. The screen will be off if there is no operation.
Also, the machine is set to have Bluetooth enabled by default out of the factory.
Additionally, is switching off bluetooth and wifi a possibility with all models? , and done the same way prescribed here?
I’m looking at the rugged ‘waterproof’ AC240P and was told by a re-seller that it’s not possible to switch it off, and I really want to.
@Irma Confirmed by the tech team: All models that support WiFi and Bluetooth support manually turning off WiFi and Bluetooth.
