Send notification when it get low on power
i have two ac180 one runs my sky and boosters the other runs the internet and printer both on smart plugs it would be good if there was a way to get notified when the battry was lets say 5% so i can then remotley turn on the power if i was out the house…
Since the AC180 doesn’t have wifi, only bluetooth, I doubt they can do this. I had similar situation and I made a best guess based on capacity of the device and the average watts pulled and use the smart plugs schedualer to occasionally turn on for a bit. I did have to fine tune it at first, but it worked pretty well.
Just make sure you have the AC180 to charge at a rate the plug can handle.
@Ktt
Previously, a BLUETTI FB group member suggested a similar idea to yours. The app team evaluated it and the response was that it is currently not feasible, and there is no push notification feature available. If there are any technical updates in the future, I will let you know :)
For me not having push or email notifications is killing my use of my AC180. I use is as a UPS and need to know when power is off and remaining battery life/time.
Please add this feature
Impossible to add a smart feature for a device that lacks the hardware capability. It literally has no wi-fi chip in it. It’s an offline UPS only. One solution you could do is simply purchase a network enabled camera and point it at the AC180 to know whether you are on GRID or battery reserve. Just set the AC180 screen timeout to never. Granted you’ll have to make sure your modem is plugged into UPS as well and network is online as well (assuming power outage didn’t take out that as well) otherwise cellular failover is required.
My solution was to buy a very small/cheap UPS and put it in front of the AC180. Grid goes out, it alerts me and starts beeping. Then if I check the Bluetti, based on the load, I know how long I have (roughly), and can run solar input or get ready to swap it out etc. The UPS also provides some additional power during grid down situations, but it’s really just there to let me know there is a problem. It cost me about $70, the one I bought was from CyberPower.
