Anyone know where to buy a ready-made right angle aviation plug, wired with about 2ft of wire? The standard Bluetti aviation plug for solar input sticks out a bit to far for me.
The plug is made by Weipu in China. Search their webpage online for that plug, but you have to find a supplier because Weipu only sells in large lots.
@philfr212 I have not been able to find a right angle aviation plug, so please let us know if you do! Cause that would be pretty awesome to have! haha
And as @Raymondjram mentioned, The AC200 uses a WEIPU SA20 2-pin plug, and both the male and female plugs can be found on amazon here…
Amazon has the right angle plug, but not made up prewired. I may have to find a friend that does good solder work.
Just checked. Amazon is male right angle - not female as required.
The PV input connector needs four pins, not just two. The AC300 has dual PV inputs.
@Raymondjram is correct @philfr212 The Ac300 has the 4pin aviation input.
I guess I should’ve confirmed with you first, but the link I put up above, gives the option to purchase either the male OR the female 2pin WEIPU aviation plug, and is what I use for my OG AC200 unit. I actually purchased both so that I can use one (the male) for the 12v/25a RV output to wire directly to my dc fuse block, and then I have another (the female) that I have for my modified 12g 50ft extension cable for solar input.
I dont have the AC200Max tho @philfr212 so does that 2pin aviation plug have the threaded "dial" on it after inserting it? Or does it have the "pull-style" lock that gets it to stay into place? The one I linked and needed for the OG AC200 is the pull-style which is the SA20 model.
The Weipu part needed is the SP21 2-16
Found it from an Amazon seller
Hi,
We have an AC200P that uses the two pin SA20 pull ring type connector. Think i know rhe answer but could really use a right-angle version of that pull ring (versus screw) connector if any knows of a supplier
