Has anyone tried to use the lithium battery blocks from inside of a Bluetti with external controller/computer/inverter?
We live off grid in Panama, and in summer 2022 we purchased 4 EP500 and 8 AC200 to power our home and different buildings. We had first purchased an AC200 Max and used it for 6 months to great effect, so we bought more. Each is a stand alone install with its own panels. The AC200Max stopped working after about a year. So did the other machines … at the 10 to 14 month mark, each machine has shorted out. The tiny yellow fuse connector on the circuit board connecting the solar charge sparked/fired. We have high quality panels, cables, circuit breakers on the cables. It seemed to be a faulty component issue.
We sent photos/videos of our entire installation (including specs of the panels, cable, circuit breakers, etc), and (after many back and forth emails) Bluetti sent us new circuit boards, which we installed, all worked great again, until now they are all dying again. Same issue. I will of course ask that Bluetti send me new circuit boards again, but if it is as difficult as it was the last time when all the equipment was only 1 year old, I expect an issue, and certainly need a longer term solution.
I have $30,000 worth of Bluetti equipment (that is now almost junk), and my estimate is that $20,000 of that is in just the batteries, which should have MANY years of life left in them. I hope to find a way to reuse them with other external equipment. Attached is a photo of the EP500 board with the shorted circuit circles in red. The exact same yellow fuse connector is the point of failure in both AC200 and EP500. In this board, only the bottom fuse fried, so the top one still works, so I can still charge the EP500 at half speed (using one set of 3 panels) instead of at full speed (using 2 sets of 3 panels). But in time, I know the second one will fry too.
NOTE … all the machines continue to accept charge via my gas generator, but that kind of defeats the purposes of having a solar system, no?
Does anyone here have any ideas? No doubt there are MANY people in my same position … a HUGE set of good batteries that need to be reused!
