Recently bought AC70 & bougeRv aspen 50 pro. My question is Amazon Prime is few days away, from a newbie wandering if I buy renogy 220w folding solar panel if I can attach it too AC70 without any electrical issues.
Yes, no problems.
The input spec for the AC70 is 12-58 Volts DC with a maximum wattage of 500W at a maximum current of 10A.
So, from the photograph your panel a VOC of 23.6V and VMP of 20.0V ok there.
So, in summary in ideal conditions your AC70 will see a voltage of VMP 20.0V with a maximum current of 10A even though your panel is capable of delivering 11.0A so giving 200W.
Happy shopping.
Thks for fast reply…yes I read the specs & realized the renogy 220w would be a good match.
Bought the 220w at good deal just waiting for package to arrive. Again thank you for information.
You will only achieve this power in theory. In reality, expect a maximum of 170W in full sun, as the panel will heat up. If the sky is cloudy, it might be 50W. So don’t expect too much.
Yes I seen some videos where the wattage went as high as 184w down to below 70. Better than driving around wasting gas…lol
Take two of these panels and connect them in series. Then you will have an optimal result. ![]()
If the optimal operating current of the solar panel exceeds the maximum input current of 10A of the Bluetti AC70, does it matter?
The Renogy’s optimal operating current is 11A.
