It would be great if Bluetti could add a feature to turn on the AC or DC outputs when you power on the unit if they were initially turned on when you turned off the unit.
I know it has the feature for system switch recovery. But that is only active when the unit powers down because of running out of battery.
I’m looking to have the feature active even when you manually turn off the unit.
Bluetti competitors already have this feature active. I know its a possible safety hazard, but there are checks and warnings that the app could give the user in the case of turning on this feature.
I have the Elite 100 v2 and the Elite 200 v2. It would be very good to add these features.
Although quick, I would imagine, hitting the inverter and battery with a load, before it has chance to fully power up, may be harmful to the electronics, especially a high load.
The actual start up process I use is; Switch the unit on, then turn AC on and then plug the device in. Those few seconds in between avoid that.
Perhaps others, more in the know might assist…
Kinda ask myself why you need the this as addition to the system switch recovery. When you turn of the unit, you need to turn on it by hand anyway, so you also can activate the outputs with the power on of the unit?!
Then perhaps they can code in a delay from when you turn on the power button and the ac switch turns on. It doesn’t have to be long because the ac and dc switches can be turned on right after you power on the system.
