Recommended gas generator for recharging
Hi all! Happy New Year!
Does BLUETTI recommend any gas generators for charging any of their solar generators. There are times when that is the only way to recharge. All suggestions welcome.
I have a Bluetti AC 300.
I tried using a Honda UU 100 but it would not work. My Honda EU 2000 worked but not constantly
I watched a you tube video where they adjusted the minimum input voltage but I can’t seem to find it.
I have a Honda es5000 that worked great.
That’s all I know.
I purchased a Dual fuel CHAMPION 2500 inverter generator. Propane and gas capable. Propane is much cleaner for infrequent use. No draining of the gas which goes bad over time,
BASS PRO Shops…about $600.
https://www.basspro.com/shop/en/champion-power-equipment-2500w-dual-fuel-inverter-generator-with-co-shield
