Question: Apex 300 power pass through
So I know if you feed 50amp into the Apex 300 it will pass through and not use the battery.
I only have a 30amp transfer switch.
If I tell the Apex 300 to limit its input to 30amp (which appears is option) will it then pass through the 30amp (via the 50amp/220output) instead of 50amps each leg? Or will it feed battery and then run off inverter. What effect would this have on battery longevity if the pass through at 30amp not possible.
Thx,
Chris
