PS54 solar charging question
New here. PS54 with 200w solar panel. PS54 manual say charge voltage 20-26v. I have a 200w solar panel that I can connect in series for 40v. I probably already know the answer…but, can charge at 40v without damage to the PS54?
Hi Bj-99 I also have a PS54. You must stay under the voltage limit or risk fatally damaging your Bluetti. The solar input is 12-28 volts (Open circuit voltage / VOC). This information is also on the PS54 under the solar input. It will only accept 200w solar max.
