Protective case for Elite 100 v2
I have just received my Elite 100 v2. I am looking for any suggestions regarding a protective hard shell, weatherproof case, with foam in it. We do mostly camping and off-roading so I want to make this investment does not get damaged or have water/dust get into it. We live in Canada so hopefully all recommendations will be available in Canada.
Hi @TanCam
Not that easy, because the Powerstation always needs fresh air around it. You cant really fully cover it. Only like a corner protector or something. Aside from 3D Print it yourself, i dont have a idea.
Welcome @TanCam you have a few options for transportation you could use a blow moulded case and insert foam yourself for protection.
You can find covers on Amazon similar to the I linked that are waterproof but also has vents for air flow hope this helps.
XCZ Outdoor Power Station Cover for BLUETTI AC180 - Waterproof Generator Protector with Ventilation & Transparent Window, Dustproof Solar Storage Cover (Black) Amazon.com
This would be for transporting/storing purposes only. It would be out of the case when in use.
Thank you @Ktt for your response. I am trying to find a blow moulded case and I would definitely insert foam in it. The problem is finding the right size. Most cases I have found are way to large. I don’t have alot of space available in my jeep and certainly don’t want to damage the Bluetti unit. I did see the covers on Amazon but I don’t believe it would provide enough protection. I just thought someone else would have found the perfect fit. No worries, I will keep searching and update when I have found something.
