Problem with the AC240P charging station
Hello. I’ve been using the station for about a year (in a gentle mode). The problem is that when the battery charge reaches 71% or less while powering my devices, the station turns off (the battery percentage on the display immediately drops to 0%). I discovered this suddenly. Another interesting thing is that if you put the station on charge, then having reached approximately 45%, it immediately gains 100% charge. I posted a video to show the problem. https://youtube.com/shorts/7iAlohloZtU
As you can see, the station shuts off when it reaches 51%. Then, while charging, it goes from 45% to 100% in one second. I tried calibration by discharging to 0% and then charging (did it 3 times), but it didn’t help.
Please respond quickly, as our electricity situation is currently dire.
S/N: 2405000060965
ARM v2161.01
DSP v2095.04
BMS v1063.03
