Hi @BLUETTI_CARE @BLUETTI
I bought the station exactly one month ago. At some point, I turned it off at 65%, and a few hours later, the station refused to turn on. Seeing that connecting via XT60 helped @lavash_bluetti @Shura @eehor, I tried it too. The station started up the first time, and I charged it a little, but when the power went out from grid, the station automatically shut down because it was not under load, and now it won’t turn on anymore. The XT60 method no longer works.
Any ideas or suggestions for a solution?
There are several other ways to start the station and use it until it shuts down on the forum. But this doesn’t solve the problem as a whole. Therefore, repair is the only option. I could be mistaken, but from what I understand from those who have had it repaired, the BMS board is repaired by replacing a thermistor of some kind and the entire central board (where the buttons and display are). They may also check the inverter board, as I’ve seen videos of repairing burned-out transistors. If the station doesn’t turn on, only a service center can restore it to normal operation.
Hi @DavidKouw, thank you for contacting us. Have you ruled out factors such as excessively high or low ambient temperature?
If DC charging doesn’t help either, we will have to arrange a repair.
Please contact our customer service team for further support.
Thank you for your concern and explanation, @lavash_bluetti.
