Premium 100 V2 SOC reading problem, calibration didn't help
My SOC readings are terrible too…
I am going to ask for BMS v1083.10 like you have.
Did you receive BMS v1083.10 you asked for ?
How are SOC readings ?
Also, consider this :arrow_down:
Hi @theadviser, thank you for contacting us.
DSP v2200.16 works fine now and as described the output Watt readings are reasonable OK now.
Unfortunately I experience some very unreliable SOC readings too…
I did some experiments with my CPAP which is a low power load of 10-11W average (heater is off)
I used it several nights on my (calibrated) 100V2 from SOC 100% till it shut off.
According to the Bluetti formula:
Runtime = (Battery Capacity × DoD × Efficiency) ÷ (Device Power Draw + 10W Self-consumption power)
with DoD = 0.9 and efficiency = 0.9, I had a total runtime that was pretty close to this formula.
So this is fine.
However…
Between 100% and shutting down the SOC and remaining time predictions were absolute unreliable and far from linear, despite I slept during the same amount of hours every night…
The last night I went to sleep with a SOC of 36% with 35 hours to go but after 5.5 hours
I woke up because the 100V2 went down…
This is of course a terrible miscalculation! Of course I would not have used the powerstation if I knew I had only 5.5 hours runtime left!
So the displayed values of SOC and remaining time are useless now.
And this happens all in despite of the fact that Bluetti states that the powerstation is also suitable for power backup of medical devices.
The 100V2 clearly has problems specially with lower loads.
(maybe because of low resolution AD converters with bad filtering, who knows…)
But I read here in this post that other firmware like BMS v1083.10 or even .99 (?) is available and seems to help.
I don’t know what I need, it is all very confusing…
Bluetti, can you send me the ‘best BMS version you have’ to solve this SOC/time misreadings ?
Thanks !
Hello; @BLUETTI_CARE
I still need an update for SOC readings.
Thank you. Received an update to BMS v1083.09. Was expecting 1083.10 or do I need to update to this version first? Nothing on the DSP.
Hi @chem, we would like to help you.
However, the SN code for the Premium 100 V2 you provided earlier appears to be incorrect, so we are unable to push the firmware.
Please note that the correct SN code consists of the model name followed by 13 digits.
PR100V2225280000420193
The SN code you provided has 2 extra digits. Could you please send a screenshot of the SN interface so we can confirm this? Once we receive the correct information, we will apply for the firmware push for you.
Hi @theadviser, yes, you are right.
To resolve this issue, simply upgrade the BMS firmware. We recommend performing a full recalibration after the upgrade.
We look forward to your feedback.
Hi @LvdK, thank you for your update.
We have forwarded this issue to our technical team again, and they have pushed the new firmware BMS v1083.09 to fix it.
What’s the difference between 1083.09 and 1083.10 and can I get the DSP v2200.16 update please
Hi; @BLUETTI_CARE
Sorry for the wrong SN. Here is a screenshot;
Thank you.
Dear @BLUETTI_CARE
Please send me a new firmware (DSP+BMS) for my Elite 100 V2 that will allow the unit to display active power continuously:
SN - EL100V22537116090524
ARM - v2186.16
DSP - v2200.14
BMS v1083.08
Hi @chem, thank you for your update.
Hi @DmitryDr, thank you for getting in touch with us.
Dear @BLUETTI_CARE
I installed the DSP update to version v2200.16.
Now the power consumption are correct. Thank you!
Thanks! I will let you know the results !
Hello @BLUETTI_CARE
My current firmware versions of Premium 100 V2
PR100V22532000082969
IOT2529015124449
IOT v8024.12
ARM v2186.16
DSP v2200.16
BMS v1083.10
After turning it off, it won’t turn on again. What should I do?
@BLUETTI_CARE still waiting to know why I haven’t been given the DSP upgrade to v2200.16 and only a BSP upgrade to 1083.09?
Hello, @BLUETTI_CARE;
Thanks for the new BMS update. Now I am using BMS v1083.09. But unfortunately problem still exists. During PV charging SOC jumped form 85 % to 100 % in five minutes.
And also I want to mention some weird behaviors about my power station
I am using my V2 as a backup for my TV setup including a 65" LED TV, PS5, Wi-Fi router, apple TV 4K, PS5 dual sense charger, aqara Hub E1 (directly inserted into one USB A outlet) and aqara T1 LED strip. Also I am using an aqara smart socket at grid connection.
I am using my V2 at PV priority UPS mode at 50 % SOC set value.
  1. When everything at standby with pass through charging inlet and output shows 55-60 W.
  2. If I close the smart plug and the grid connection output value rises to 90 -92 W.
  3. During PV charging when it reaches 10 % higher than the SOC set value, power station shuts off the grid connection and output value jumps to 90-92 W from 55-60 W. But even with a closed grid connection smart plug measures around 12 W electricity flow. And when I switch off the smart plug output decreases from 90 -92 W to 80-82 W. Can power station draw power from the grid at this situation?
Thanks for the reply.
Utku
