Premium 100 V2 SOC reading problem, calibration didn't help
Hi everyone!
It’s much simpler. Bluetti and other station manufacturers display a unit called WATTS on the screen. WATTS measure active power. This is clearly stated on the screen.
Best regards!
Hi @VSM,
Our discussion ends here. I do not appreciate the way you speak to me.
You are indeed asking for perfection. You need to come to the conclusion that sensors in power stations typically have an accuracy of around 1–2%. What you are asking for is 0.1%, which is no longer basic functionality. In addition, you do not understand how the composition of the current values affects what is shown on the display; this is about the Power Factor. Furthermore, you keep referring exclusively to other brands; that is comparing apples to apples and, in my opinion, not particularly meaningful.
Put very simply: a cheap AC power meter does not show everything, such as:
  • Voltage
  • Current
  • Frequency
  • Power Factor
  • Active Power
  • Reactive Power
  • Apparent Power
  • Active Energy
  • Reactive Energy
It usually only shows:
  • Voltage
  • Current
  • Active Power
And some AC power meters also display frequency. The BMS uses all of these values, and that is what is shown on the power station’s screen. So my point is that both readings are correct: those from the BMS (measured internally and displayed) and those from the external AC power meter.
But this is where our conversation ends. I wish you happy holidays and a happy new year.
Hi @Lavash_bluetti,
Yes, the device does show watts. However, some people have questions about how these values are derived, calculated, and displayed on the power station’s screen.
They measure externally using an AC power meter and rely on data from that device, while the BMS measures internally and displays those values on the screen. The issue is that, in some cases, the values do not match because the power factor is not perfect, which can cause the power station to display higher wattage values.
People performing these external measurements often use inexpensive AC power meters that do not account for the power factor or other factors in the final displayed values. They then compare their externally measured values with the internally measured BMS values, and these do not always match. That is what this entire thread is about.
Hi @Tezzabee,
Sorry, I think we’re not on the same page, and I don’t fully understand your issue. Do you happen to have your own thread about this problem on the forum?
If so, could you please send me the link to the forum thread, so I can read your posts and better understand your situation.
Finally. I stopped reading here btw :joy:
Hi guys! What was the actual full (from 100% to 0%) capacity of your Elite 100 v2 measured by power meter at AC output?
@Scholar with 750W load from the heater, I got:
  • 945Wh on BMS v1083.07
  • 922WH on v1083.09
  • haven’t tested it on v1083.10
Hi @BLUETTI_CARE
Have a similar issue with incorrect values on display
Can it be fixed?
EL100V22526000353216
IOT v8024.12
ARM v2186.16
DSP v2200.14
BMS v1083.08
Thank you!
@BLUETTI_CARE and in current state it starting to charge even when it’s connected to grid and AC load connected to station, so again - no passthru mode even for AC load? For DC, as I understand, there is no passthru mode, ok, but for AC - it was there, but now - after some time station starting to charge from 99%
Please give me confirmation that this behaviour is expected
Thank you!
That’s normal. The station still uses some power for its own needs (~12 Watts for this model) even in passthrough mode, draining the battery, then recharges to 100%.
I have AC180P and AC200PL, and they do the same. I don’t think you can make it so that all internal electronics shift self-consumption from the battery directly to the grid (well, that’s my guess; I never owned an Ecoflow/Anker, etc.).
@BLUETTI_CARE received my elite100v2 5days ago. have been testing.
dc & ac idling loss is actually perfect. (wifi/bt/screen all off) DC losses 0.5% an hour, AC losses 1% an hour. very linear drop. In line with official words from bluetti, 5-6watt idling for DC 10-1 watts idling for AC.
display Active power is wayyy off. starting from 40w and on. Some examples
wattmeter - 41 watt → bluetti shows 75 watt
154 195
355 462
561. 776
795 953
897 1039
1741 1958
which module controls display wattage? ARM or DSP or BMS? need this updated
Аналогичная проблема с корректным отображением мощности есть и в модели premium 200v2
Но меня ещё интересует вопрос потребления энергии из сети,когда стоит режим ups custom и стоим по времени розряд АКБ,то станция из сети потребляет от 20 до 120Вт и при этом на дисплее 0
Нагрузка на станции около 100-200Вт
Что это за паразитные потери?зачем
Вот на фото пример,идёт розряд АКБ,но и из сети 44 Вт потребление :exploding_head:
Почему так
Когда UPS standard,заряд 100% то потребление из сети 3Вт
Это в принципе допустимо
https://community.bluettipower.com/t/power-draw-from-the-grid-during-peak-hours/
https://community.bluettipower.com/t/heavy-grid-usage-when-not-charging/
Уже поднимали эту тему. Это проблема режима “Custom UPS” во всех моделях, где он есть.
Hi @George2050, Your firmware has been upgraded successfully—please do not attempt to upgrade it again. Additionally, could you try re-calibrating the device and then test the effectiveness of the updated firmware?
  1. Please discharge all the power (charge AC & DC appliances with the power station) until the SOC is 0%, turn off the machine, and leave it for 3 hours till it cools down.
  2. Please charge it again. Please do not load any device when charging it, and do not interrupt it while it is charging.
Hi @tempal, Regarding the first question you raised, we have applied to push a firmware update for you. This firmware will enable your Elite 100 V2 to display active power at all times.
As for your second question, we consider this a normal phenomenon. When the power station is connected to a power source, it will start charging automatically and stop only when fully charged. Once the battery level drops to 99% after being fully charged, it will resume charging again.
Hi @100v2, When the apparent power of your Elite 100 V2 under load exceeds 50W, the LCD screen will display the apparent power; when the apparent power is less than 50W, the LCD screen will display the active power.
We have currently developed a new BMS firmware that will enable the device to display active power at all times. Please provide the SN code and current BMS version of your Elite 100 V2, and we will apply to push the firmware update for you.
Thank you @BLUETTI_CARE , will update and check.
Another question: after some of the previous updates I lost the ability to switch station off completely (both via app and via harware buttons) when it’s connected to grid.
Earlier I was able to switch it off without unplug it from the grid, now I can switch it off only when power cable is unplugged or when there is no electricity in my grid. Is it OK now or it can be fixed?
Thank you!
@BLUETTI_CARE Привет!
Балансировку делал. У моего экземпляра Elite 100 V2 та же проблема, о которой пишут все - неправильное отображение нагрузки.
Пожалуйста, отправьте для моего экземпляра Elite 100 V2 новую прошивку для BMS, которая позволит устройству постоянно отображать активную мощность.
BLUETTI Elite 100 V2:
EL100V22527008961344
BMS v1083.08
Спасибо за поддержку!
Hi @BLUETTI_CARE
Can you please check/confirm again: I have no updates that you’ve mentioned.
Same versions as in my initial message:
IOT v8024.12
ARM v2186.16
DSP v2200.14
BMS v1083.08
I’m still have incorrect values on display.
In this issue that now I can’t switch the station off (via button or app) when it’s connected to the grid.
Thank you!
@BLUETTI_CARE Hello, thank you, will be waiting for firmware.
SN - EL100V22542003762464
current BMS firmware v1083.08
