Featuring a 2600W high power and a 2073.6Wh capacity, the Elite 200 V2 offers robust load-bearing capabilities, making it perfect for all scenarios. From outdoor adventures to emergency backup power at home, this powerhouse has you covered.
I have never understood power Lifting. I tried it on a 3100W air fryer on the 200L and it could not do it and errored out - but it’s meant to be up to 3600w
Sorry, but the power lifting mode work if the device is a purely resistive load.
The air fryer is not strictly speaking a purely resistive load, so it is normal for errors to occur.
Is it compatible with your expansion battery’s.
And do you need to use them in power bank mode?
Really struggling to see the use case for this. It seems like a downgrade all around. Fewer ac and dc outputs than prior models, and removed the ability to connect expansion batteries. What got better?
The Elite 200 V2 has been upgraded in terms of battery cells, structural design, and the app. It features automotive-grade square battery cells with 6000 cycles, the longest in the industry. Its wireless structure reduces energy consumption and extends battery life.
Regarding interfaces and expandable batteries, the R&D team made decisions with a deep consideration of cost for the users.
When will it be available in Europe?
Perfect, thank you for reply!
Just realized that the Elite 200 comes with two sets of MC4 connectors, both connected in parallel. Two sets of two MP200 or two PV350 should be possible with 10% “overamp”.
