I have 2 bluetti generators AC200P and EB70.
I was charging the EB70 with a Dokio flexible panel but having less than 35V VOC I can’t use it with the Bluetti AC200P.
Having had enough of deploying the folding panel in front of my roof windows, I’ve just bought 1 revolt panel that are the right size for my roof end.
Small hitch: no matter what type of cable I use, this panel doesn’t work with either the EB70 or the AC200P,
I had taken care to buy a panel with a VOC above 35V (advice given by bluetti after-sales service) but I don’t know enough about solar energy to understand the problem.
The AC200P worked very well with a 450W panel on another site, so I don’t understand where it’s stuck?
I put the links to the Revolt panel purchased for the characteristics and also 2 bluetti,
Thank you in advance if anyone can shed some light on this problem. See you soon!
Panneau solaire monocristallin 150 W avec connecteur compatible MC4 | Panneaux solaires et éoliennes | Pearl.fr … atible-mc4
https://fr.bluettipower.eu/products/ac2 … uk-version
Hello. Here’s what’s happening with your 150 W Revolt panel (Voc 43.71 V, Vmp 38.72 V, Imp 3.87 A):
EB70 won’t accept it
The EB70’s MPPT only handles panels up to Voc 28 V and 200 W max. Your panel’s 43.7 V exceeds that, so it won’t charge.
Specs: Solar Input 200 W max., Voc 12–28 V, 8 A → see Bluetti EB70 manual: https://bluettipower.co.uk/products/bluetti-eb70-portable-power-station
AC200P is only a marginal fit
The AC200P needs a panel with Voc 35–150 V and up to 700 W. Your Voc sits just above 35 V, but in anything less than perfect sun it will dip below and refuse to charge.
Specs: Solar Input 700 W max., Voc 35–150 V, 12 A → see Bluetti AC200P details: https://www.bluettipower.eu/products/bluetti-ac200p-power-station
How to fix it
For the EB70: switch to a low-Voc panel (e.g. a 12 V/200 W unit with Voc ~22–27 V), or add a DC–DC buck/MPPT regulator to step down to 12–28 V.
For the AC200P: wire two of your 150 W Revolt panels in series. That doubles Voc to ~87 V and Vmp to ~77 V—comfortably within 35–150 V—and doubles your wattage, too.
Always use a proper MC4→DC adapter cable rated for solar, plugged firmly into the PV input.
Once the panel voltages match each unit’s window (and you’ve got the right cables), both stations will charge reliably—even in less-than-ideal sunlight.
Hi Vik, sorry for late answer and big thanks for your clear complete answer.
I still need your help because I know nearly nothing about solar.
on this photo above is it this a controler correct for the eb70 ? and a question remains_ to reach a controller like this I need a cable with mc4 on one side and nothing on the other side?so I plug the bare cable into the controller and mc4 to the pannel. And how do I go from the controller to the EB70 ? Cheers
I have finally sent back the solar panels150w.
I still need answers to these 3 questions:
1~ is there a type of non-folding panel measuring around between 110 x90 cm that can charge both the bluetti eb 70 and the bluetti ac200P (not at the same time)?
2- what should be the characteristics (in terms of a range, not a precise value) of a panel that can load the bluetti eb 70 in a day: Pmax . Vmp.Voc.Imp.Imc
3~ Same question as 2 but for the bluetti Ac200p .
I hope that someone will answer so that I can buy the correct panel and not have to spend money buying something that I have to send back.
Thank you
I think you panel up the AC200P to max of 700 watts, but over panel to 800 or 1000 watts. Run in series. The low voltage requirement of the EB70 of 28 v . That doesn’t make sense to try and use 1 setup to solar power two different units with a large range in PV voltage . Plus the minimum of 35 V on the AC200P doesn’t meet the Max of EB70 28 V. That won’t work no way.
Use the AC200P with as much watts it can handle to PV charge the unit. And charge the EB70 from the ac outlet of the Ac200P
