Was running my Instapot and now have this on the display. The Instapot only draws about 700 watts. Came back a few minutes later and now have this on the display. Turned the unit off and on several times and did factory reset with the app. Thoughts?
Any other loads connected to the AC180? It can only do a “total” of 1800 watts continuous across all loads.
Example: If you ran a hair dryer at 1500W, you would only have 300 watts of “continuous” power remaining, not another device capable of 1800W as well.
Resistive loads like electric kettles can cause a problem if its on for a long duration of time.
Hi @timtew, Could you please tell us the specific model of your Instapot?
Thanks to @sealy1986 for the helpful answer, which is very informative. Additionally, we need to know the specific details of the load to understand its current requirements. Sometimes, the current required by the load is too large, leading to an inability to carry the load.
Is the load normal after connecting to the grid? If the load is removed and other low-power devices are used, does the error still occur?
We look forward to your reply.
