Operating temperature below 32* for the AC300
The AC300 owners manual lists the lowest operating temperature at 32F. Is this absolute or recommended? What is the effect of operating below 32?
The intent is to use the AC300 for winter camping, sometimes down to 20*.
@Tahome If the ambient temperature is lower than the operating temperature of the machine, the machine will give a low-temperature warning and will not be able to work normally.
Hey @Tahome, sounds like fun to go Winter camping. Perhaps if you have the ability to put your unit in some kind of insulated box it could still work? Put a thermometer in there as well to keep an eye on the temperature maybe too, because you also don’t want it to overheat again of course when it’s switched on.
