No output on ac180
Hi ,
Just used my bluetti ac180 for the first time.
Had a 650w kettle plugged in and working ,but when i turned on the 1150-1260w coffee machine output stopped and will no longer turn back on ,I had the power uplit enabled.
What have I done,am I able to reset anything, I have pressed the reset on the side of the machine but still no output, also unable to turn on out via the phone app.
Phil.
turn it completely off and then back on again. If that does not work, try pressing the AC output button for 30 seconds. Lastly, is your 180 at 10% or higher state of charge? If not charge it.
@Cam46ie3 The machine may be overloaded. I suggest you remove all loads and reboot the machine.
