Need help with purchase
Hello guys i just redeemed a bluetti mini fridge on site it showed awaileble 74 now 73,
when i reedemed it showed a message out of stock the screen flashed and something but my points still missing didnt recive any email abou the fridge redeemed .
Wanted to ask if the order is registered or i got only an error thanks for the help ,it doesnt show up at all orders or processing order .Thanks :D
my Bluetti bucks where taken but didnt recive anything
I have a distain for Peltier-based (aka thermoelectric) coolers also known as mini fridges. They are junk. The Peltier element generally consumes around 50-60W constant but only has the capability to cool down the fridge to 30 degrees below ambient. This isn’t a compressor based fridge which can adequately cool the inside. It’s not even refrigerator at all by definition. You know what can cool down beverages and run less than 60W constantly? AN ACTUAL refrigerator. Save your money.
thanks alot for the info apreciate it :smiley: i know its only a small coller and not a real colant fridge:D
Right so in a car in the summer the interior can get 100+ degrees F inside, which means the lowest the beverages will be inside is 70-100 degrees depending on cabin temperature. The worst place possible IS the car (unless you are driving with AC on then it will do its job). This essentially limits their effectiveness to a 100% climate controlled room.
yea was thinking the same when i go camping with the ac on here in romania 40 celcius so it will be 22 maximum with ac 26 -18 (8) i will use it only in car outside its usless maybe heat up some food with it or keep warm :smiley:
il get it with points dont pay for it i would never buy a peltier fridge with money :D
Hi @meiger, We’re happy to assist you.
Based on your description, it may be that a front-end system error caused points to be deducted without automatically generating the order.
Please contact us via private message and provide the email associated with your account, and we’ll arrange for a manual order to be created for you.
@BLUETTI_CARE did you recive my message?
stock is fine but when i press redeem screen flashes that loadin 10 sec and then i ghet this
Hi @meiger, Yes, we have received the information you sent, and the screenshots you provided are very helpful.
We have already forwarded this to the European Sales Manager, based on the error message, it seems that the order couldn’t be placed due to insufficient stock. We’ll investigate this matter tomorrow. If it’s confirmed that the issue is caused by delayed stock updates, we’ll adjust the stock quantity according to the actual situation.
