An MQTT connection for the EP 600 would not be bad. If you could read out the current values, you can integrate the system much better into your SmartHome. Primary reading would be enough… However, for security reasons, you should only be able to write with a password (turn off SystemSwitch, etc.)
@Kbuettgen After confirming with the techs, this feature is not supported yet. I’ll let you know later when this feature is available.
Hey @Kbuettgen
You may wanna have a look at this:
There are a few projects that do this. Its basicly a device that connects via bluetooth to the Powerstation and send the data via MQTT to homeassistant for example
Hope this helped
Yes, I know the software! But it would certainly be “safer” if BLUETTI would install this feature itself.
Atleast a lot of easier to configure ;)
Any news on this feature? Sure would be great to have!
Well, unfortunately the last IOT update brakes the connection to the bluetti-mqtt project (and I´m not enough of a python developer to fix it myself I think)
I would open an issue on there github page. Shouldnt be a problem for someone to fix code thats already there.
I think thats because EP600/EP760 got some changes in the Bluetti App. The Github project is just reverse engineered.
I’m running the bluetti-mqtt projekt on the ESP32 version from Mario Lukas, with some changes on the code.
With the last IOT Update Bluetti changed the Type from Serial Number [EP600xxx] to Serial Number [PBOXxxx]. So you have to change it in the code too if you use it with a EP600. Yust type your PBOX Number as Serial Number in the bluetooth connection.
Maybe the python code ned a fix too … I dont know, the C++ Code needed a little fix on the config header file …
+1 for home assistant integration from Bluetti
Has somebody news about the MQTT connection from Bluetti? Would be realy nice :-)
Hi @gyurasan
There arent any official MQTT implementation for Bluetti Products yet.
Hm what about a REST API. Would be very nice for reading the basic values and us it else where.
Bluetti dont have any open API. Just the Bluetti App that some dudes on github reverse develop
Hi dear Admin,
any news on this? We´re all really waiting for this feature…or pretty much any API, local or to the cloud, that would allow retrieval of live data… please?!
@tscher This feature is currently in planning, and it is not yet clear which company we will partner with.
@BLUETTI Hi dear Admin… another half year passed - any news on this? Pretty pretty please… that iot controller thing is in the wifi already, can´t be that hard to implement any local api? MQTT, REST, Modbus, JSON, raw ASCII, raw binary, we don´t care… I don´t even need to control anything, just make the status data available… pleeeeeease?
Thank you for your continued attention to this matter. The technical engineering manager replied: Currently, the hardware conditions for the BLUETTI EP home storage series are in place, but it has not yet been integrated. I will let you know as soon as there is news of a successful connection. ![]()
