Mppt for pv350
Recently bought an ac180 with max solar input of 60volt and 10amp and pv350 watt solar panel which works great.Would it be ok to connect the pv350 straight to my motorhome 12 volt habitation battery through a Victron 75volt,10 amp mppt.
Hi @Naylor, Regarding this issue, we confirm that you can use that brand of charge controller.
However, please note that the open-circuit voltage of the PV350 is 46.5V, with a maximum power of 350W. The Victron has a maximum input voltage of 75V, so you can only connect one PV350 to the Victron.
When charging a 12V battery, make sure to connect it to the 12V output on the Victron.
I hope it does help.
