I have an ac300 with a b300 attached, can I add a b230 alongside the b300?
It is not recommended to connect different models of battery packs, which will lead to a large difference in SOC between the two packs.
If the battery pack is lower than the host’s power, there will be a situation where it cannot be charged.
Is this also true for AC200MAX with B230 and B300?
can i charge a b230 with a b300 and vise versa?
Please, give some instructions on how to correctly charge the mixed set of AC200MAX with B300S.
Which is the correct way:
- Charge AC200MAX separately and then B300S (or vice versa)
- Charge both using the AC input to AC200MAX (but it has a smaller capacity)
- Charge both using the AC input to B300S
