I have two B300 batteries. I have maxed out the Solar input for the AC300, with two separate Arrays of 1200 watts each, using six identical Solar panels.
My question is regarding the direct Solar input. The limit is 12-60 volts, 10 amp max. Also the the second input available is using the D050 DC charging enhancer.
This input is also rated for 12-60 volt 10 amp maximum.
Can these two inputs be combined? can this be done while the battery is hooked up to the AC300 , and other B300 batteries, or does the battery need to be separated from the AC300 while maximizing the direct solar input to individual batteries?
