Why can’t i charge my EP500 pro with my 2000watt inverter on my RV when on the road. I always get a low volage error. I also have over 900w of solar power.
What is your incoming AC voltage from the inverter? Also, what is giving the low voltage error? The RV inverter or your EP500 pro?.
If your RV inverter is giving you the error, it would be due to the inverter not being receive sufficient voltage from your batteries. This is usually due to your (RV) batteries not having sufficient charge or the wiring from your (RV) batteries to the Inverter is too small or the length of the cable run is too long.
My voltage coming from my inverter is 106 AC.
The AC output voltage from your RV on board inverter is too low. It should be in the 115 at a minimum to around 125 volts
