Low grid voltage error (E114) on AC70P
Hi, I have the same error (E114) because of low voltage (~180v). Please upgrade my firmware.
Model: AC70
SN: AC702425000218338
IoT: v9046.04
ARM: v2151.05
DSP: v2106.06
Yes,please give us the sn code of your device, then we can push the new firmware to you.
Hello, I have registered your firmware upgrade. Please wait patiently.
How quickly are updates delivered?
Maybe my message got lost?
Sorry, I wrote this two days ago:
Hi @BLUETTI and @BLUETTI_CARE , I live in Ukrane and have low voltage issue E114 error(around 180-195volts), can you help me with new firmware? Thanks
Model: AC70P
S\N: AC70P2403001037488
ARM: v2122.07
DSP: v2112.06
BMS: v2112.06
Hi @Alexx, we have pushed the new firmware DSP211272 to your unit.
Please upgrade and test it.
We hope it does help.
Thanks a lot @BLUETTY !
New firmware DSP v2112.72 for AC70P
works perfectly and charge normally even a low voltage!
(and do not dropout error E114)
Hi @BLUETTI ! Have the same issue with low voltage charging, please push upgrade to my device, thanks
Model: AC180P
S\N: AC180P2511000037580
ARM: v2125.04
DSP: v2126.03
BMS: v1048.05
Hello, @BLUETTI_CARE
I posted my message two days ago, but I didn’t received any answer.
I will post it again.
I have the same problem. I live in Ukraine, and there is an unstable grid.
I have an error message E114. The voltage for our grid is less than 200V.
Sometimes it is around 170V.
Could you push custom firmware for low voltage charging for my device?
SN: AC2A2535000878888
IOT v9046.04
ARM v2145.04
DSP v2101.03
Hello, I have pushed the new firmware to your device. Please wait patiently.
Hi all, for Ukrainian users who are unable to perform AC charging under low grid voltage conditions, please click the link below to fill in your SN, DSP version, and other relevant information.
https://feedback.bluettipower.com/questionnaire/69707f00fbdb8877850611a2
We will push the new firmware to resolve this issue. Thank you for your cooperation.
Hi @BLUETTI ! Have the same issue with low voltage (~180-190v) charging, please push upgrade to my device, thanks
Model: AC70P
S\N: AC70P2510000640236
IOT v9046.01
ARM v2152.04
DSP v2112.06
Hello, please fill in your information in the form as instructed in the post.
