Is it possible to utilize a Lithium battery instead of the lead-acid battery when using the Charging Clamp accessory?
Yes, you can you any source as long as the voltage requirements are met
Thank you for the response.
I did get a response from Bluetti and is below;
Thank you for reaching out to us.
If you want to charge our AC200/AC200P/AC200Max/EP500Pro/AC300 power stations with battery, it should be Lead acid battery. And you need to purchase the lead-acid battery charging cable. Also, it should be noticed that your battery should be 12/24V.
If you have any further questions, please feel free to contact us.
Best regards,
Icy
Not sure why it would have to be a lead-acid battery.
Yes, but a 12 VDC litium battery is quite expensive because it must have its own integrated BMS to prevent overcharging (and possible damage), overdischarging, and heat damage. Lead-acid cells are over 150 years old and are well established. This is why even new electric cars from all vendors still use a lead-acid 12 VDC battery.
I am experimenting with both lithium-ion (4.2 V) and lithium iron phosphate (3.2 V) cells with BMS to replace my 12 V lead-acid battery in my Ford Fusion Hybrid. Thr LFP cells are better but more expensive now, yet I expect to see them as an option for all cars by 2030 or sooner.
Doesn’t have to be a lead acid battery
