🌿 Join BLUETTI Elite Camping Challenge, Win Elite Gear!
Calling all minimalist campers! Show us how you create the ultimate ā€œless gear, more comfortā€ camping experience powered by BLUETTI’s newest:
:battery: Elite 30 V2 (ultra-portable)
:battery: Elite 100 V2 (more power, still compact)
:dart: The Challenge:
:one: Pick ONE BLUETTI Elite model as your power core (Elite 100 V2 or Elite 30 V2)
:two: Build your ideal setup with no more than 5 devices (coffee maker + string lights or projector + mini fridge?)
:three: Share a 1-minute video OR some of your real camping photos! Don’t forget to submit your topic with #EliteMiniCamping
:trophy: Prizes List:
Grand Prize: Elite 100 V2 Ɨ1
Creativity Awards: Elite 30 V2 Ɨ2
Lucky Awards: 3000 BLUETTI Bucks
*BLUETTI reserves the final interpretive rights for this campaign.
:alarm_clock: Submit by July 6! Power your perfect minimalist camping with the Elite 100/30 V2 Tiny Gear.
:bulb: Pro Tip: Going full #glamping? Check out our Apex 300 + B300K combo for luxury outdoor power.
Well done Bluetti for this competition. I will not be entering as I have already received several prizes/rewards from previous posts on the Forum. Time to give others a chance. :grin: I might learn something as well.
My Forum participation will continue, particularly re Off Grid camping use and occasional part Grid Backup scenarios.
Good luck to all whom enter. :ok_hand:
I’ll share my literal setup and my justification for why I use each device at each power station. Nothing to do with this contest, just sharing for knowledge.
Bluetti AC180 #1
DC
Iceco APL55 Dual Zone Fridge (located in backseat of my truck)
AC
(None)
Bluetti AC180 #2
DC
Mifi Router
12V Charge source for EB70S (piggybacked)
AC
Mainstays 0.7cu microwave
Midea 22 Pint Dehumidifier
Western Digital EX4100 File Server
Dell Inspiron 3670 Desktop
Bluetti AC70
DC
Surface Laptop (over USB Type C)
Small media consumption tablet (USB Type A)
Phone (USB Type C)
AC
Dreo CF511 (air circulator)
Asus MB249C 24" Portable Monitor
Bluetti EB70S
DC
Maxxair 4050K
HardKorr LED Lights
AC
(None)
Bluetti EB3A
DC
12V Air Compressor (to pressurize 3.8 Gallon Self-Pressurizing WaterPORT Day Tank)
IcyBreeze Ultimate (circulates cold water through a heat exchanger and water pump to cool you down)
AC
Laundry Alternative Ninja 3200 RPM Centrifugal Spin Dryer (located in backseat of my truck)
Ryobi battery charger for 18V power drill (PCL206B), sprayer (P28140VNM), and handheld vacuum cleaner (PCL700B)
Solar Charging Sources
Bluetti AC180 #1 is charged by 360 watt solar blanket, Bluetti AC 180# 2 by Bluetti PV350, Bluetti AC70 by another Bluetti PV350, and Bluetti EB70S by Bluetti PV200.
Justification
I dedicated Bluetti AC180#1 to just running my 12V fridge. It is the most power hungry device I own and having a large battery bank with large solar potential is critical for my set up. In an emergency since both my Bluetti power stations are parallel to each other against the back of my truck bed, I can unplug the 12V cord from Bluetti AC180#1 and plug it into Bluetti AC180 #2 to keep the fridge alive if I have ample power left. I can sacrifice not using the dehumidifier or microwave for that day for the sake of keeping my food cool. My truck has a 400W outlet and I utilize a Bluetti T200S 200W charger to car charge the AC180#1 while driving. Idling the truck for an hour or two may give me JUST enough juice until Sun comes out to top it off the following day.
For Bluetti AC180 #2 I mostly use this to run my dehumidifier (on cool humid nights only mostly), and my microwave. The reason I use the larger AC180 is inverter efficiency for higher load appliances is greater for larger inverters than smaller ones. In other words, if your load is 200W or more, use a larger powerstation like an AC180. If your load is smaller (50W or less) use a smaller inverter (i.e. AC70/EB3A/etc).
For the Bluetti EB70S, this was the 2nd Bluetti power station I ever purchased and was looking for a way to repurpose it. So I partitioned it to run just my Maxxair fan and lights only. Since the lights and fan max out at around 50W DC, a 200W solar panel can easily maintain a net charge during the day. Generally I can get away with even less if I don’t run the lights during day and put fan at around 50-70%. It will only use about 15W then! If for whatever reason I need to supplement a bit more charge, I piggybacked my AC180 #2 into the EB70S through a parallel y splitter connection (DC7909) and all I have to do is simply enable the DC port to charge the EB70S from the AC180 #2. It’s less efficient granted, but otherwise wasted energy if I DONT use it. Think about if I wanted to run my lights at night and my fan, but I only had 20% left on the EB70S. If I knew it was going to be Sunny out the next day, who cares if I drain the AC180 down 50%, I’ll get it topped off the next morning anyways. A 100% full battery is wasted energy if you don’t use it.
For the Bluetti AC70 this mostly serves as my power source to run my air circulator in my Moonlander. The fan is AC powered, but the inverter is more efficient than my AC180, and still has a large enough capacity that I can last through a night. The added bonus of 500W solar charging allows me to top off the battery quicker too. I have a larger portable monitor as well that acts as a nice large viewing screen for entertainment (if I don’t want to look at a small tablet or phone), but since the portable monitor uses less than 50W, the inverter is ideal for this type of load as well over the AC180.
For the Bluetti EB3A this is my portable/take anywhere power station. If I want to take my camping chair outside and sit on my laptop I can utilize the USB Type C port. Likewise I use this power station to carry it to the backseat of my truck to run my spin dryer. The spin dryer uses about 400W when in use so the 600W inverter runs it no problem. Inverter efficiency is poorer, but the trade off is worth it for portability. Since you can only run the spin dryer at a max of 5 minutes per load, I only consume less than 10% per session.
Why so many power stations?!
My floor configuration is specifically optimized for the amount of space the two Bluetti AC180s, AC70, EB70S, and EB3A take up in the truck. Originally when I bought my two Bluetti AC180s it was because they perfectly fit in the back wheel well of my F-150. I wasn’t thinking anything else other than maximizing my use of my space. But then I realized there are two key advantages here! REDUNDANCY and WEIGHT SAVINGS. Way easier to carry two 35lb power stations than one heavy one like an AC200 (60+lbs) or Elite 200 (53lbs). Because I have two power stations I can easily transfer duty from one power station to the other (like in the case of my fridge) and simply take the other power station out and fast charge it when the opportunity arises. So I can stop by McDonalds and get a bite to eat, transfer my 12V fridge from AC180 #1 to AC180 #2, then take the AC180#1 inside McDonalds and fast charge it at 1440W! Finally nice to have a redundant failover if one power station fails, there is no interruption. I can send the unit back for repair while still using the other one for my needs.
The A in AI this time stands for ATROCIOUS.
:evergreen_tree: Story: ā€œThe Night We Lit Up the Forestā€
(Featuring the BLUETTI Elite 100 V2 as our power hub)
After weeks in the city, my partner and I decided to escape into the woods with one rule: bring less, live more. We chose the BLUETTI Elite 100 V2—compact, powerful, and ready for adventure. With it, we knew we could enjoy true comfort without the weight of heavy gear.
:electric_plug: Our 5-device minimalist setup:
Portable mini fridge – to keep our gourmet picnic fresh: cheese, fruit, and chilled lemonade.
12V electric coffee maker – because nothing beats a warm coffee at sunrise in the wild.
Portable projector – we turned a white sheet between two trees into our own outdoor cinema.
String lights – wrapped around our tent and table, adding warmth and charm to the forest.
Bluetooth speaker – soft music played as we dined under the stars.
:canoe: While the forest slept, we enjoyed a night of cinema, good food, and the kind of peace only nature can offer. The Elite 100 V2 powered it all seamlessly.
:milky_way: As the lights dimmed and silence returned, one thing was clear: less really can be more.
#eliteminicamping
@Helenacelma @Bernyator @MARTIVILLAR
Please note that this event requires real camping photos; AI photos will not be counted. :handshake:
Please also submit a topic and attached hashtag #EliteMiniCamping, as these are also conditions for valid entries. :blush:
Put the topic into an admin approval mode so bots can’t mass spam AI crap (i.e. comments have to be approved by mod or admin first)
We encourage all our members to share your joyful moments from camping. :camping: :camping:
Select one Elite power station, submit your ideas, and add #EliteMiniCamping to join this campaign! :beers:
Night had fallen over the forest, but my adventure was just beginning. With the BLUETTI Elite 100 V2 as the power core of my camp, I set up my minimalist haven under a clear, star-filled sky.
First, I plugged in my portable coffee maker—because every good night starts with a great cup of coffee. As the rich aroma filled the air, I strung up my fairy lights, casting a warm, cozy glow between two trees.
A few steps away, my mini fridge kept a few bottles of kombucha and fresh fruit nice and cool. Then came movie time: my portable projector lit up a white sheet hanging between the trees, turning the woods into an open-air cinema. To complete the mood, I connected my Bluetooth speaker, playing soft ambient music as I settled into my camping chair.
Power was never a concern—my BLUETTI ran everything silently and cleanly, right in the heart of nature. That night, in my little corner of the world, simplicity met luxury—all powered by clean energy.
#EliteMiniCamping
@Irene @Amparo @Havi @BVG Please use only one account to participate and read the rules carefully. You need to open a new topic.
Hello. Could you help me set a topic? I don’t know how. Thanks in advance.
@BVG Please go to the forum details page.
https://community.bluettipower.com/categories
Click +NEW TOPIC botton at the top to post.
I tried to post it correctly a while ago, but I can’t see it here. Can you confirm that I did it correctly this time?
They are all (likely) bots with AI generated content/images. All the bots liked their own posts. The names are also a dead giveaway.
Hi! No, I’m not a Bot, I don’t know about the others. I created a new topic and posted the photo, but I see it’s not showing up here, and I don’t know if I did it right.
Bad bot.
They will respond with natural language to deflect from the fact they are AI.
Okay. I see you’re laughing at me. I won’t answer you again.
Wow, I’ve been working on multiple tracks in parallel this semester and did loose track of the new Bluetti devices.
This EL100V2 seems like a wonderful successor to AC180.
Ā
  • 20Amps of solar input mean it can make the most of 2 rooftop panels in parallel.
  • -4kg makes AC70 impatient to see an EL70V2 bridge the new portability gap :slight_smile:
  • Smaller profile… wow… again, AC70 territory with bigger AC180 guns.
Just shared a few ideas regarding how this could improve my landscaping / offgrid days:
