Issue with UPS Mode on Bluetti EB3A
I am the owner of a Bluetti EB3A and have been using it for 6 days. I use it for my working equipment (PC, Wi-Fi router, audio speakers), with a total power consumption of approximately 120 -130 watts.
I am experiencing an issue when using the device in UPS mode. My device shuts off for a few seconds and then turns back on. This causes connected devices to reboot, which is very inconvenient and poses a risk of data loss and PC breakdowns.
Here are some details:
  • I noticed the shutdown occurs when the battery is at 100% charge.
  • The shutdowns happen even with a small load (less than 100W).
  • The device is running on the latest firmware version.
  • This problem sometimes repeats itself 3-4, or even 5 times in a row, with intervals of seconds. After the first short shutdown, the PC begins to reboot but does not complete the process as the shutdowns occur repeatedly.
  • In offline mode (without being connected to a power outlet), I did not encounter such problems.
I have tried the following steps:
  • Upgrated the firmware to the latest version.
  • Disabled eco mode.
  • Reduced the load on the device.
  • Changed the power outlet to which the device is connected.
Despite these efforts, the problem persists. I believe this might be related to the overcharge protection mechanism or other internal inverter settings. Could you please help me resolve this issue? Are there any additional steps or settings I can check?
Thank you for your assistance.
Best regards,
Ihor
Hi @Ihor.Hrytsiuk
welcome to bluetti community forum!
I found a topic, which describes your problem pretty well.
Maybe you can try the suggestions from this thread.
Привіт!
Started getting same issue few days ago. Any working solutions?
I have no working solution yet. The problem is still relevant, in addition, I noticed the shutdown occurs also when the battery is charging
seeing that you have the same problem as I do and it’s been a month without replies from @BLUETTI_CARE I guess they don’t know what is going on
