Im pretty sure that your batteries parasitic drag from inverter is only happening when AC is on , and not when DC ON andAC OFF, but wanted to be 100 per cent .
Thats true as its the inverter that provides AC power. There is still some parasitic draw if the DC is left on as well, but much less than the inverter. I believe the battery pack voltage is around 58 VDC so it needs to be processed somewhat to provide 12 VDC and 5VDC to the DC side.
