Integration of AC180P with monitoring server
Hello everyone!
This is my first post on the forum.
I’m using my new AC180P and so far everything is perfect, but I’d like to create a script that allows me to extract values ​​such as battery charge, line voltage, load delivered by the inverter, etc from an Ubuntu PC.
From what I’ve been reading, the AC180P only allows encrypted BT connections (I’m not sure if it’s LE or standard).
I found the bluetti-bluetooth-lib and bluetti_mqtt libraries. Has anyone had experience using them successfully with the AC180P? @BLUETTI @BLUETTI_CARE
Thanks in advance!
Kind regards,
Daniel
Hello! Is your request regarding Bluetooth decryption? If so, please provide the SN code of your device and your email address so that we can assist you better.
Thank you for your support!
Hello! Thanks for replying.
First, I’d like to know if both mentioned libraries (bluetti-bluetooth-lib and bluetti_mqtt) are compatible with the AC180P.
Regarding the SN, I will check the app. Is there a private channel through which I can provide you with this information? I don’t see any direct messaging option when I go to your profile.
Kind regards,
Daniel
