Is it possible to increase the wattage capability of the AC200P by adding one from the EB series
@LouGee EB series models, it is the host not the battery pack. The hosts cannot be connected to each other, much less expanded.
I have a Ac200p which has a wattage output of 2000W, my requirements have increased therefore I need to upgrade, what are my options
Add a B230 expansion battery.
if I’m going to spend $1300+ for a B230, can I use an AC200max instead?
Adding a B230 expansion battery increases the Wh battery capacity by 2048 Wh; but does not increase the power, Watts, output of the power station. ![]()
An AC200MAX has an output power of 2200 Watts. ![]()
Is that going to be enough ??
i’ll require 3500Wh, so what do I need if I want to increase Wh and wattage power
Read up in the Bluetti website, start with the AC300, then up, and up … AC500 and up in power, Watts, capacity.
https://www.bluettipower.com/search?type=product&q=Power+stations
Also search here for the specific power stations, and also search YouTube !!
