Impact of low grid voltage
Hi,
@BLUETTI_CARE
I have the AC300 UK Version and I am concerned that sometimes the grid voltage is quite low - 206v, instead of 220 - 240v. What is the impact of charging the unit on this low a voltage? And if there is any adverse impact, what is the solution if I wanted to use it in UPS mode and charge from the grid only?
There is no alarm coming on. But I was wondering whether there might be a long term impact if it continues like this.
Rgds
@ayo Did your AC300 report any error codes?
Hi,
No error codes, which I thought was weird.
A
Hi @ayo
The tech team indicated that if the machine is not displaying any error codes and charging normally, there is no cause for concern—this will not adversely affect the battery. :handshake:
Thanks. Out of interest, how low can it go before an error code is triggered?
It is 70% of the standard voltage.
