How do you set the Time on the AC200L?
I’m using it only in offline mode connected via Bluetooth.
I have no way to verify that the time is set properly, as neither the app nor 200L actually display the time.
How do I set the time, and how can I verify that it’s set?
The manual doesn’t say, and I can’t find this info online…
@jCs As long as you connect the AC200L via Bluetooth, it will synchronize the display time on your phone to the AC200L. It is also important to note that the time zone of the APP need to be set correctly as well.
Thanks @BLUETTI . How can I check what time is set to the AC200L to make sure the correct time is set?
I have custom UPS mode set, which may rarely trigger, and i’d like to verify that the timing will work as expected.
@BLUETTI In addition to my post above:
I just enabled Energy Statistics, and can see the clock is incorrect: I enabled just 30 minutes ago, and Energy Statistics shows data from many hours into the future, from into the next day.
The AC200L is connected to wifi, and the controlling device’s time is also certainly correct. The app is set to the correct time zone given my Location information.
So I’m wondering again: how can I set the correct time?
It’s certainly not correct as it is.
While I don’t use custom UPS mode, I have noticed my statistics are always off also, which is a bit annoying. Would also like to know how to properly set the time on the AC200L.
“Is the time zone set correctly on the app?” @BLUETTI Yes, it’s set correctly. (From my last post: “The app is set to the correct time zone given my Location information.”)
@BLUETTI Sure: ipad (iOS) running 17.6.1 OS
Screenshots: happy to provide screenshots. can I send these over email or private chat, so that I don’t post screenshots of my location on a public forum? Although, all the screenshot would show is a correctly set location.
