How to make sure B300 is genuine
Hi
How to make sure the BLUETTI B300 is genuine and not used before when buying via reseller?
Do you have a list of authorised stores in Ukraine?
@Oleks
Stylus Store is our distributor in Ukraine.
We haven’t come across any pirated products yet, and as for whether they are brand new or not, you can usually only recognize them by their appearance.
Hi @Oleks
in addition to @BLUETTI answer, maybe you also can somebody from the bluetti team check you serial number of the B300 to see if its a valid one.
I have an AC200MAX + 1xB300 battery and can’t find the B300 in the confirmed stores, but the B300S is available in stock.
Is it not compatible with my setup and I need to find B300, not B300S?
Hi @Oleks
B300S is only compatible with AC500. You need to have a B230 or B300 for you AC200Max
Hi @Selfmadestrom
Thank you :+1:
