Hi, everyone,
I joined the Bluetti community today because I have a question or two that needs answering. I recently purchased an EB3A Bluetti generator. It is a 268Wh LiFePO4 battery backup with 600 watts (1200 watts Surge). I think it will do fine for my purposes.
However, I desperately need help selecting an appropriate generator, likely by Bluetti, that will meet my sister’s needs to run her sleep apnea machine (CPAP) should the power go out. She has terrible sleep apnea and would not be able to sleep a wink without her CPAP working.
I do not know the model number of her CPAP machine, but when I googled what CPAP wattage machines use, I received the following statement that confused me: math was never one of my best subjects. It stated the wattage of most CPAP machines is between 30-60 watts. Watts is a unit of power and a function of current (amps) and volts (Watts= amps x volts). If you’re running your CPAP off a battery, you need to know the power demand in ampere-hours. I do not understand this formula.
In my scenario, let us assume that my sister’s CPAP machine uses an average maximum of 60 watts. When it says that number, what does it mean? Does it mean the machine uses 60 watts per hour or 60 watts continuously, like every second it is running? I am unclear and would appreciate any feedback that would elucidate the issue. If you know a great article explaining this question, I am okay with it if nobody is keen on writing it out for me.
I need a generator that can handle a 60-watt draw for 9 hours with at least 20% power remaining. Is the number simply 60 watts multiplied by 9 hours, giving the number 540, with 540 meeting 540 watts? If this were the case, my 600-watt generator would be enough power for her. Is that correct?
Based on the formula above, I do not think it would be that simple. Can someone please tell me how to determine how many watts the generator must be to run the 60-watt CPAP machine for nine hours? Explain it to me like I am five if it can be done.
If you have made it this far, thank you so much for reading my questions. I greatly appreciate any help with my problem, and I appreciate your feedback.
