Hello! I have seen a lot of video reviews about EB70 and manuals but as a result get 2 different ways in how to charge with AC wall outlet:
Plug cable to AC wall outlet and only after that to the EB70
Plug cable to the EB70 and only after to wall outlet
I just want to understand the order and not harm the device. Please help what order is correct
BLUETTI
December 15, 2022, 3:26am
3
Hi @Kostiantyn , The two ways you mentioned are available, don’t worry.
Thank you! I got another question: should I turn on AC power button and then plug in device to EB70 or should I plug in device first and on only then turn on AC power?
BLUETTI
December 16, 2022, 2:22am
5
It is recommended that you connect the two first, and then turn on the power.
Thank you for your answer
