How do you get the DC Hub to stay on?
I have a DC Hub connected to my charger 2 (connected to AC200l via B300k). It is being installed in a camper van, and I am finding that the DC hub will turn off when it’s not in use for an extended period of time (2hrs), or even when a device with low current draw is being used. This is not an acceptable setup for a camper van, I need DC power on demand as long as the AC200l and Charger 2 are online (which seems to be the case with eco turned off). Is this how it is designed or is my system behaving incorrectly?
  1. Make sure the P090D connector is locked. If it is not properly seated the power button will flash twice every 6 seconds to tell you that. If you ignore it, it may eventually detect an unstable connection and shutdown. 2. Update firmware to address any software related triggers causing sleep mode.
