Ordered the solar panel adapter and hooked it up and nothing no imput into the EB55 checked the solar panel and its puting out 90 w…dose any one have a idea?
Hi @Tibor , Do you mean the panel has output, but the machine has no input?
Is the solar chaging connection cable connected properly? By what means did you measure that the solar panel has 90W?
Could you please try to see if the machine can be charged by car charging?
Your solar panel wiring may be opposite polarity (+ and -) from the input to the EB55. The negative and positive must match the EB55 and the MC4 solar charge cable requirements.
