Home Dialysis machine
We currently use a home Dialysis machine every night. The machine runs off and on for 3 hours over an 8 hour time frame at 600 Watts. What Bluetti power supply would handle this load due to power outage?
Probably one of the 200 range. I would suggest the AC200L @ 2,048Wh capacity or the AC240 @ 1,536Wh capacity, either will suffice and both have expansion battery capability. Personally the higher capacity of the AC200L is my preference. Be aware not all power stations have expansion capability.
Depending on expansion battery you can get up to 8,192Wh of total capacity, over 10 uses without a recharge. (2 x B300 expansion batteries). Other EBs will work, but do your homework re total capacity. Info is available on Bluetti’s web site.
Thanks to Mike for the recommendation of our 2kWh models. @Mandp
@Larry1 Hi Larry,
If you are in the US, I would recommend purchasing the Apex 300. The US-spec Apex 300 has a 0ms switch UPS, and it has more power and battery capacity, so you can use it with greater peace of mind.
You can click on the following Indiegogo campaign link to learn more.
