Hello. I am from Ukraine and I received the EBA charging station as humanitarian aid.
When the input cable is connected, the inscription UPS flashes and the station does not charge. What shall I do?
Also, when I try to connect through the application, I get the following error:
Hi @yevkin , Sorry for the inconvenience.
Can you please share the SN code of the machine? I can have a technical engineer unbind the device for you first.
As for the UPS flickering issue, what method are you using to charge it? Try other charging methods, will it work properly?
Is this a serial number? EB3A2230001979049
As for problems with charging, I think I understood, now our voltage often drops below 200 volts and then it does not charge, when it is higher, then it is normal.
